Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GT 250 R with EFI has FI Indicator light on and only runs for a few seconds Reply To: GT 250 R with EFI has FI Indicator light on and only runs for a few seconds
Dec 26, 2023 at 11:44 AM
#12043
Remove the filter from line between the pump & injectors as that will cause a problem, I think it’s one step at a time, check & clean with contact cleaner as many connections as you can find particularly the ones fitting the sensors as corrosion in any of these will play havoc
