Trevor
  • Topics: 1
You should look for the 2-pin plug that’s under the rear seat , on the left side (as if you were behind the bike facing yourself towards the front of the the bike)
So I bridged the two pin connector and nothing really seems different.  I’m going to swap the spark plugs out and look for the tool to do the compression tests but I’m not sure what to look for in dealer mode.  I’ll check the manual but just wanted to see if there was any thing special to look out for
