neil low
Had this problem on my TDM , went through the same rigmarole as you (grrr) fuel down the bores etc , turns out that the wire that went to the fuel injectors had coroded,  so plenty crank but no start , replaced wire and Bingo she started , hope this helps , cheers from Scotland
