Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Changing out choke cable on 2008 gt650R Reply To: Changing out choke cable on 2008 gt650R
Nov 27, 2023 at 12:13 PM
#11779
Hey welcome Justin!
Honestly , You can do it while the airbox is still attached to the bike. You would just need to gently lay a big old rag on the floor, drop the fairings slowly.
You should see a choke cable hooked on a carb rail , it will be held down by a hook that pulls it when you activate the choke lever.
