Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Gv250 misfiring Reply To: Gv250 misfiring
Nov 26, 2023 at 8:40 AM
#11760
Sounds like either the wiring that goes to the front coil has issues or it is the ecu. Have you tried switching the front and rear fuel injectors as well?
just finished putting the bike back together after swapping the fuel injectors around, it seems to be the problem now the front exhaust is getting nice and hot and the rear one is staying cold, so now il order a new injector or two and see if that fixes the issue, thank you very much John
