Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Electrical problem with my Hyosung GT125R Reply To: Electrical problem with my Hyosung GT125R
The fact it’s both sides messing around says its probably the connector blocks behind the headlight unplug spray with contact cleaner, the starter switch could be the side stand switch playing up.
Lights going dimm when pressing start usually means either of these:
- Tank Tap has burst,causing fuel to keep flowing to the carb , causing cylinders to hydrolock (dangerous), remove “OIL FILLER” plug on your clutch cover and sniff hard. if you smell fuel, drain oil, replace oil filter, service the carb, replace intake orings , and definitely replace the tap Or Lift tank safely , and cover electronics (be wise!!) , disconnect fuel pipe from the tap and see if tap bursts fuel in to bucket while bike is totally off. I say use extreme caution as petrol fumes near battery can easily cause instant flames should spillages happen. You have been warned 😬
- Relay is burst (common)
- Battery too old or weak. Get it tested free at halfords or bike shop with their own “specialized bettery gauges”
- Battery too small (too low CCA to crank 2 pistons)
- Charging system wanning (causing battery to have low volts to start next time) common culprit is a regulator (which can annoy the stator next and kill it)
- Starter Motor too old (last but not least, but it is not uncommon)
Good luck and see about doing what Simon said above ^
Hi again, I recently noticed that if I turn off the light switch, the bike starts with the first push of the start button.
PS: I don’t think it’s hydrolock because the bike starts after pushing the start button 3 to 5 times with the light on. Also, I don’t believe it’s a battery issue because when the starter begins cranking, it performs very well.
