Aug 23, 2023 at 11:41 AM
#11040
ISCV on EFI? On the schematics i only found tps (throtle position sensor) and AIPS (air intake pressure sensor)
Yes every EFI Hyosung since 2008 has had an ISCV to control the idling speed, otherwise , you might have an early batch of the GV12-S that doesn’t have it ? Sometimes it acts as a fast choke to warm up the bike in brutal winters
Also i know for a fact Hyosung used 2 variant’s of ECU’s , early vs later model, the later models use a DELPHI ECU with twin plugs and a whole new harness (assume this means electronics also changed to delphi)
Ie. 2008 GV250 Had SENTEC ECU with sentec marked electronics vs a 2016 that had DELPHI and everything else was delphi branded
