Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Looses power and cuts out at high speed Reply To: Looses power and cuts out at high speed
Jul 25, 2023 at 7:59 AM
#10856
Hi again. As per your advice measured the compression it’s 12bar on each cilinder. Took of carburetor took it apart and cleaned everything. Put it back together now it starts but won’t rev up. Dies as soon as any throttle applied. Checked for vacuum leaks with brake cleaner all seems good. New spark plugs. Upgraded fuel filter from your site. Hoses not bent fuel coming through. Fuel pump has pressure when pipe removed shoot petrol out. Complete lost at this stage.
