Anthony
  • Topics: 2
I checked the taps and fuel pump already. They’re working fine. Fuel is making it to the carbs. I also checked for spark. It’s getting spark. I haven’t replaced the plugs due to me observing it gets spark. I’m not sure if that could be an issue. When I set the idle screw I turned 2 1/2 out. Which most carbs are. Not sure if that can be a issue but its as before I cleaned the carbs. No difference. Starter fluid let’s it run for maybe 2 to 3 secs before dying back out. I’m still stuck staring at the bike in frustration because it doesn’t even have 1000 miles on it yet. Any and all suggestions will help
