If the bike “cranks” ,  the Stator unit’s pickup sensor must tell the black box on the bike to engage sparking system  (coils and caps)
I’d look at the stator pickup sensor , it might be reading 100 ohms stand still, but may read zero if crank spins ,  so it can flactuate if it is wanning   (wanning parts trigger the black box to cut sparks off)
Check also side-stand switch  (bypass it and waterproof it well)
Clutch Switch (don’t bypass, as fake neutrals can happen and you don’t want to start her and watch the bike fall down when it’s in first gear even though it says Neutral, a squeeze on the lever gaurantees your presence as you crank to start and let it idle when its safe to let go of the lever)
HT wire – could be breaking up inside ?
That is if the HT Cap itself is on a good ohm spec by its own.
Hope this helps and keep us updated
