Jun 29, 2023 at 7:45 PM
#10618
Tried your last. No result unfortunately
i have a feeling it’s time to get a new harness and ECU at this rate.
Otherwise , can you confirm please
– If the bike ignition plug is removed it still runs?
– if the starter motor is disconnect , it still runs?
– If you remove the HT caps ? what happens ?
Sorry to ask these 3 , if you could give me 3 answers , it helps be sure what the actual cause is because it’s not a carb bike (easy to diagnose) but an EFi model, so we have more electronics to be careful with that’s all .
