Paul
  • Topics: 4
I’ve now had chance to look at this and its all a bit confusing.
Battery is holding steady at 12.8v.
I have 12.8v on the red wire at the ignition switch.
Once the ignition is on i don’t get 12.8v on the orange wire  at the ignition switch.  After i turn the ignition switch to on i get about 0.5v on both wires.
I would have expected 12.8v on the orange wire after the ignition is on, and the same going back to the relays and switched fuses.
Could it be something putting load on the ignition?
