For Fuel Gauge Reading = It is Yellow/Black (wire one) and it goes straight to the dashboard.  And second wire is Black/White , it is just basically ground to chassis or battery negative.
Does this help ? If i missed something in your post shout away.
You can still save the harness , strip it all down , patch what you can and use  MANNOL Harness Tape (recommended) or similar
For connector (plug)  it is called “2.6mm (i think)” “Auto Car Electric Plug” it is what hyosung uses for that 2pin style connector, it is the same connector style used for
– side stand switch (sometimes this is bypassed by last owners and recommended to bypass!)
– Rear Number Plate Light
