Apr 19, 2023 at 3:29 PM
#10203
I’d just seal it up with a sheet of 3mm plastic. Avoid using through bolts if you can. You don’t want hardware going through the engine.
The hyosung doesn’t like pod filters, many of us worldwide have tried to use pods but the bike becomes unstable and its a very frustrating war of messing with the carbs everyday. Trust me, the airbox wins. As Jim said above ^ , why not a metal/plastic sheet there and use “JB WELD EPOXY HIGH TEMP” for plastic. This could be the cheapest and easiest solution. No screws. Otherwise it may rattle and end up inside the engine and it explodes , very good advise from Jim
Ok, I’ll do that, today I’ll probably go to the garage. As soon as I fix it, I’ll update.
Thank you so much.
