Ok thanks I did that, I took it out for a short ride afterwards and when I parked there was light smoke coming off the engine from the heat. I think it could be running lean since I got higher end air filter or could possibly be smthn else?
i would also look to change the jets as “more air” = lean mixture , engine overheats , could burn oil as piston rings can only tolerate so much.  There is a jet tutorial on forum if you have seen it ?
As for crank smoke , go with Simon’s comments
