Apr 10, 2023 at 1:02 PM
#10116
The ad says 20w , i assumed every bulb , then its 80watts if all light up at once! – Could cook the harness since if you notice your highbeam lights draw 55w, and their wires are thicker than the indicator wires ( watts vs current (amps) vs ohms, if you want to get technical calculating it yourself) = The harness has a 15A rating.
Hopefully the seller said its actually 5w per bulb 🙂 , after a ride just check the buzzer winker relay isn’t hot or anything.
